Bug #350
open
MO
I225 PCIe device not detected on Harcuvar
Bug #350: I225 PCIe device not detected on Harcuvar
Added by Mathieu Othacehe over 4 years ago.
New
04/25/2022
Hello,
I'm working on an Harcuvar devboard (serial PWHA61500083) flashed with coreboot master branch (aade40c3).
I plugged a PCI QNAP 2G1T I225 PCI/Ethernet device on the Harcuvar PCIe x8 slot.
The device is not visible by coreboot and not listed in the lspci/dmesg output of
the mainline Archlinux distribution I'm using.
On an other machine, the PCI QNAP 2G1T I225 is correctly detected and the corresponding "igc" driver is loaded.
I plugged a completely different PCIe device (serial converter) on the same slot. It is detected correctly and
visible by Linux:
[DEBUG]  PCI: 00:09.0 scanning...
[DEBUG]  PCI: pci_scan_bus for bus 02
[DEBUG]  PCI: 02:00.0 [1c00/3253] enabled
[INFO ]  Enabling Common Clock Configuration
[INFO ]  PCIe: Max_Payload_Size adjusted to 256
[DEBUG]  PCI: 02:00.0: No LTR support
[DEBUG]  scan_bus: bus PCI: 00:09.0 finished in 22 msecs
whereas for the I225, nothing appears on the same bus:
[DEBUG]  scan_bus: bus PCI: 00:09.0 finished in 4 msecs
any idea what could go wrong here? A boot log with the I225 device plugged is attached.
Thanks,
Mathieu
Files
boot_i225_not_detected.txt (132 KB) boot_i225_not_detected.txt Mathieu Othacehe, 04/25/2022 12:41 PM
No data to display
