Bug #336
openIntelmetool makefile problem
make states, that pci and zlib libraries are not installed, but they are. I guess, theres a problem regarding the makefile?
I tried it with Debian 11 (Bullseye) and Ubuntu 20.04 (Focal Fossa).
Can anyone confirm this issue?
IV Updated by Idwer Vollering almost 5 years ago
Yes, this is odd. Did you install the debian/ubuntu package 'build-essential'?
Can you run, and paste the output, from:
- dpkg -l | egrep 'libpci|zlib'
- in the util/intelmetool/ directory: make --trace
The expected outcome is:
$ make --trace
Makefile:64: target 'pciutils' does not exist
printf "\nChecking for development libraries: pci and zlib... "
Checking for development libraries: pci and zlib... echo "$LIBPCI_TEST" > .test.c
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function .test.c -o .test -lpci -lz >/dev/null 2>&1 &&
printf "found.\n" || ( printf "not found.\n\n";
printf "For RPM based distributions like Fedora, please install pciutils-devel and zlib-devel.\n";
printf "For DEB based distributions, please install libpci-dev and zlib1g-dev.\n";
rm -f .test.c .test; exit 1)
found.
rm -rf .test.c .test .test.dSYM
Makefile:42: target 'dep' does not exist
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function -MM *.c > .dependencies
: update target 'intelmetool.o' due to: intelmetool.c
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function -c -o intelmetool.o intelmetool.c
: update target 'me.o' due to: me.c
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function -c -o me.o me.c
: update target 'me_status.o' due to: me_status.c
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function -c -o me_status.o me_status.c
: update target 'mmap.o' due to: mmap.c
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function -c -o mmap.o mmap.c
: update target 'rcba.o' due to: rcba.c
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function -c -o rcba.o rcba.c
: update target 'msr.o' due to: msr.c
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function -c -o msr.o msr.c
Makefile:33: update target 'intelmetool' due to: intelmetool.o me.o me_status.o mmap.o rcba.o msr.o
cc -O0 -g -Wall -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-unused-function -o intelmetool intelmetool.o me.o me_status.o mmap.o rcba.o msr.o -lpci -lz
MM Updated by Max Mustermann almost 5 years ago
I was able to track the issue by editing the makefile:
pciutils:
@printf "\nChecking for development libraries: pci and zlib... "
@echo "$$LIBPCI_TEST" > .test.c
@$(CC) $(CFLAGS) .test.c -o .test $(LDFLAGS) >/dev/null 2>&1 &&
@rm -rf .test.c .test .test.dSYM
I removed /dev/null 2>&1 to see the output:
Checking for development libraries: pci and zlib... /bin.sh: 1: cc: not found
not found
ubuntu@ubuntu:~/coreboot/util/intelmetool$ sudo update-alternatives --config cc
update-alternatives: error: no alternatives for cc
I don't had 'build-essential' installed. I usually never build anything. First time for me.
So yeah... after installing 'build-essential' everything worked as expected.
Could you please update the makefile and give a hint, that 'build-essential' has to be installed as well?
As a linux newbie, it took me a lot of time and external help to find the issue.
Thank you :)
BR
Max
Sorry, i wasn't aware about the wiki. It clearly states, that gcc is necessary.
https://www.coreboot.org/Build_HOWTO#Requirements
I still would appreciate if you could update the makefile, since "libpci-dev and zlib1g-dev not found" is incorrect/imprecise.
