Bug #325
openAsus P5QL-EM: NVIDIA card in PCIe X1 port not working
When using my nvidia geforce GT 710 in PCIe X1 slot the screen is not working after graphic driver is loaded. With nomodeset parameter it works but without driver I can't start Xorg.
The same card in X16 slot works, but I want to use the X16 port on this board for a nvme adapter card.
I discussed the problem with nouveau project and they consider some sort of DMA problem and found some differences between vendor firmware and coreboot that may cause the problems.
They also mention some kernel parameters to work around this problem but even with this parameters the screen flickers when using Xorg.
With original vendor firmware the card works in X1 port.
I use this card:
https://www.asus.com/Motherboards-Components/Graphics-Cards/ASUS/GT710-4H-SL-2GD5/
Here is the link to the nouveau ticket.
https://gitlab.freedesktop.org/drm/nouveau/-/issues/132
I will also add the kernel log and lcpci output and the cbmem output.
And here are some information about the differences:
Coreboot:
Latency: 0, Cache Line Size: 64 bytes
Capabilities: [100 v1] Virtual Channel
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Vendor:
Latency: 0, Cache Line Size: 32 bytes
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
The host bridge also has SERR+ on coreboot vs SERR- on vendor.
And the root ports actually have a lot of differences, including stuff like
Coreboot:
Capabilities: [40] Express (v1) Root Port (Slot-), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (ok), Width x0 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Vendor:
Capabilities: [40] Express (v1) Root Port (Slot+), MSI 00
ExtTag- RBE+
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <256ns, L1 <4us
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+
Slot #0, PowerLimit 10.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
Changed: MRL- PresDet- LinkState-
Files
FO Updated by Francois Ollonois almost 5 years ago
- File p5ql-em.config p5ql-em.config added
NH Updated by Nico Huber almost 5 years ago
Just a hunch as DMA was mentioned: please try with iommu=off in the kernel command line. If that helps, please provide a kernel log booted with vendor BIOS.
- File dmesg_iommu_off.txt dmesg_iommu_off.txt added
iommu=offin the kernel command line. If that helps, please provide a kernel log booted with vendor BIOS.
with iommu=off I get a little bit further but the screen gets still stuck. The kernel log looks a little bit different with some more errors related to usb.
I attach the log.
