Bug #289
openThinkpad T410i does absolutely nothing
Hi,
my Thinkpad T410i is driving me crazy.
I've tried almost anything to get this laptop running in the last few days but it won't.
The current symptoms are, regardless what i am doing:
- Power On
- The laptop starts itself
- The CPU fan is starting to rotate for a few seconds
- The power button is starting to stay green (ON)
- The display LED at the display is going on for 1 second
- The light at the top of the display is going on for 1 second (light for better reading in the dark?)
- The laptop reboots itself after approx. 30 seconds
- The LEDs at the top of the keyboard are going on for 1 second
- Continuing at point 3.
The display stays black.
No beep or something else.
The best is the following: the exact same symptoms are present when i'm starting the laptop WITHOUT any RAM installed!
Some of you may want to ask me if the laptop is functional in general?
Yes it is. If i'am flashing the original ROM containing the BIOS from Lenovo and everything is working absolutely normal as expected.
/* Environment */
Coreboot Version: Master from 28. Jan. 2021
SEABios Version: Master from 28. Jan. 2021
Lenovo Thinkpad T410i
Modell 2518A3G
Embedded Controller Version: 1.18
BIOS Version: 1.45 (6IET85WW)
CPU: Intel Core i5 M520
Dual Graphic Cards (Integrated Graphics Controller and NVIDIA Corporation GT218M [NVS 3100M])
RAM: 4GB 2Rx8 PC3 10600S-9-11-F3 and tried also 4GB 2Rx8 PC3 10600S-9-10-F2
00:00.0 Host bridge [0600]: Intel Corporation Core Processor DRAM Controller [8086:0044] (rev 02)
00:01.0 PCI bridge [0604]: Intel Corporation Core Processor PCI Express x16 Root Port [8086:0045] (rev 02)
00:02.0 VGA compatible controller [0300]: Intel Corporation Core Processor Integrated Graphics Controller [8086:0046] (rev 02)
00:16.0 Communication controller [0780]: Intel Corporation 5 Series/3400 Series Chipset HECI Controller [8086:3b64] (rev 06)
00:16.3 Serial controller [0700]: Intel Corporation 5 Series/3400 Series Chipset KT Controller [8086:3b67] (rev 06)
00:19.0 Ethernet controller [0200]: Intel Corporation 82577LM Gigabit Network Connection [8086:10ea] (rev 06)
00:1a.0 USB controller [0c03]: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller [8086:3b3c] (rev 06)
00:1b.0 Audio device [0403]: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio [8086:3b56] (rev 06)
00:1c.0 PCI bridge [0604]: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 [8086:3b42] (rev 06)
00:1c.3 PCI bridge [0604]: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 [8086:3b48] (rev 06)
00:1c.4 PCI bridge [0604]: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 [8086:3b4a] (rev 06)
00:1d.0 USB controller [0c03]: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller [8086:3b34] (rev 06)
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 Mobile PCI Bridge [8086:2448] (rev a6)
00:1f.0 ISA bridge [0601]: Intel Corporation QM57 Chipset LPC Interface Controller [8086:3b07] (rev 06)
00:1f.2 SATA controller [0106]: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller [8086:3b2f] (rev 06)
00:1f.3 SMBus [0c05]: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller [8086:3b30] (rev 06)
00:1f.6 Signal processing controller [1180]: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem [8086:3b32] (rev 06)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GT218M [NVS 3100M] [10de:0a6c] (rev a2)
01:00.1 Audio device [0403]: NVIDIA Corporation High Definition Audio Controller [10de:0be3] (rev ff)
0d:00.0 SD Host controller [0805]: Ricoh Co Ltd MMC/SD Host Controller [1180:e822] (rev 01)
0d:00.1 System peripheral [0880]: Ricoh Co Ltd R5U2xx (R5U230 / R5U231 / R5U241) [Memory Stick Host Controller] [1180:e230] (rev 01)
ff:00.0 Host bridge [0600]: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers [8086:2c62] (rev 02)
ff:00.1 Host bridge [0600]: Intel Corporation Core Processor QuickPath Architecture System Address Decoder [8086:2d01] (rev 02)
ff:02.0 Host bridge [0600]: Intel Corporation Core Processor QPI Link 0 [8086:2d10] (rev 02)
ff:02.1 Host bridge [0600]: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 [8086:2d11] (rev 02)
ff:02.2 Host bridge [0600]: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved [8086:2d12] (rev 02)
ff:02.3 Host bridge [0600]: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved [8086:2d13] (rev 02)
Build environment (again) freshly built today incl. xgcc and such.
To transfer the ROM i am using a Raspberry 3 with an Pomona Clip.
KConfig:
Tried nearly everthing:
- Board T410i and x201
- with VGA ROMS extracted via sysfs, without
- with VGA ROMS dumped from memory, without
- with microcode, without
- with several SeaBIOS versions
- restored the original BIOS and flashed only the BIOS partition via flashrom
- flashed the full 8MB ROM or partly (.BIOS)
- attached the extracted ME, GBe, Descr., detached it (loading only BIOS to flash)
- with me_cleaner, without
I'am currently out of ideads and can not simply attach a serial line for debugging :(
PM Updated by Paul Menzel almost 6 years ago
If you are unable to attach a serial console, please try getting the log using EHCI debug or SPI Flash console output by selecting CONSOLE_SPI_FLASH and reading it out of the flash ROM chip afterward. See the Kconfig help text for more information.
