Bug #286
closed
JF
"-fcommon" support in gcc version 10 - coreinfo "multiple definition of" build failure
Bug #286: "-fcommon" support in gcc version 10 - coreinfo "multiple definition of" build failure
Added by James Feeney almost 6 years ago. Updated almost 6 years ago.
Closed
11/03/2020
Copied from: https://github.com/seemoo-lab/owl/issues/32
"Starting from the upcoming GCC release 10, the default of -fcommon option will change to -fno-common - this leads to build error"
Copied from man 1 gcc:
-fcommon
In C code, this option controls the placement of global variables defined without an initializer, known as tentative definitions in the C standard. Tentative definitions are distinct from declarations of a variable with the "extern" keyword, which do not allocate storage.
The default is -fno-common, which specifies that the compiler places uninitialized global variables in the BSS section of the object file. This inhibits the merging of tentative definitions by the linker so you get a multiple-definition error if the same variable is accidentally defined in more than one compilation unit.
The -fcommon places uninitialized global variables in a common block. This allows the linker to resolve all tentative definitions of the same variable in different compilation units to the same object, or to a non-tentative definition. This behavior is inconsistent with C++, and on many targets implies a speed and code size penalty on global variable references. It is mainly useful to enable legacy code to link without errors.
So then, make -C payloads/coreinfo ends with:
/usr/bin/ld: /var/src/coreboot/coreboot/payloads/coreinfo/build/libpayload/bin/../lib/libpayload.a(exception.libc.o):/var/src/coreboot/coreboot/payloads/libpayload/include/x86/arch/exception.h:64: multiple definition of `__packed'; /var/src/coreboot/coreboot/payloads/coreinfo/build/libpayload/bin/../lib/libpayload.a(main.libc.o):/var/src/coreboot/coreboot/payloads/libpayload/include/x86/arch/exception.h:64: first defined here ...
Trying to simplistically prepend CFLAGS=' -fcommon ' make -C payloads/coreinfo just changes the build flow, giving:
cc1: fatal error: /var/src/coreboot/coreboot/payloads/coreinfo/build/libpayload/include/kconfig.h: No such file or directory
Trying to judiciously add a CFLAGS += -fcommon to the payloads/coreinfo/Makefile is beyond me. It changes nothing and produces the same original "multiple definition of" error.
Somebody who knows more about this, please comment.
JF Updated by James Feeney almost 6 years ago Actions #1
Arch Linux gcc 10.2.0-3
JF Updated by James Feeney almost 6 years ago Actions #2
Downgrading to gcc8 makes no difference, so this problem with linking apparently has nothing to do with the version of gcc. In Arch Linux, ld here is part of binutils 2.35.1-1.
JF Updated by James Feeney almost 6 years ago Actions #3
Hmm - I did a git pull today, 2020 Nov 12, rebuilt coreinfo, and now everything links without problem. Whatever - this issue has resolved itself.
NH Updated by Nico Huber almost 6 years ago Actions #4
Sorry this tracker is not very active. Thanks for your report, anyway. It was the right thing to do :)
The issue should be fixed with commit: c98baa7a80 (libpayload: Add compiler.h to compiler parameters). As you already confirmed it's working, I'll close this.
