Bug #269
open
PM
ppc64le: `superiotool.h:12:10: fatal error: sys/io.h: No such file or directory`
Bug #269: ppc64le: `superiotool.h:12:10: fatal error: sys/io.h: No such file or directory`
Added by Paul Menzel almost 6 years ago. Updated almost 6 years ago.
New
07/06/2020
superiotool fails to build with the error below on ppc64le with Ubuntu 20.04.
$ make V=1
Checking for pciutils and zlib... found.
cc -O2 -Wall -Wstrict-prototypes -Wundef -Wstrict-aliasing -Werror-implicit-function-declaration -ansi -pedantic -D'SUPERIOTOOL_VERSION="4.12-1133-g4d38c7546c"' -DPCI_SUPPORT   -c -o superiotool.o superiotool.c
In file included from superiotool.c:3:
   12 | #include <sys/io.h>
compilation terminated.
make: *** [<builtin>: superiotool.o] Error 1
$ dpkg -S sys/io.h
libc6-dev-amd64-cross: /usr/x86_64-linux-gnu/include/sys/io.h
The header is in the “x86 package” under /usr/x86_64-linux-gnu/.
PM Updated by Paul Menzel almost 6 years ago Actions #1
The same is true for util/ectool.
