Bug #242
closed
PG PG
Building with vboot fails in a confusing way when pkg-config isn't installed
Bug #242: Building with vboot fails in a confusing way when pkg-config isn't installed
Added by Patrick Georgi about 7 years ago. Updated over 6 years ago.
Resolved
11/15/2019
vboot uses pkg-config to find the right compiler options to link in libssl into futility (the userland tool for key management). With that not installed, the build will go through until the linker step fails because openssl symbols are missing.
Provide better output for
  • pkg-config missing
  • pkg-config installed but libssl not found by it (not sure what that looks like today)
PG Updated by Patrick Georgi over 6 years ago Actions #1
  • Assignee set to Patrick Georgi
PG Updated by Patrick Georgi over 6 years ago Actions #2
