Bug #208
closedemulation/qemu-armv7: Fails to build a QEMU/ARM
Fails to build a QEMU/ARM with a coreinfo payload. An error is:
ERROR: Ramstage region _postram_cbfs_cache overlapped by: fallback/payload
Makefile.inc:1171: recipe for target 'check-ramstage-overlaps' failed
The same problem seems to happen since 2017 [1][2].
[1] https://coreboot.coreboot.narkive.com/fUz0RT5Z/error-ramstage-region-postram-cbfs-cache-overlapped
[2] https://mail.coreboot.org/pipermail/coreboot/2017-February/083336.html
The details I did are:
$ make crossgcc-arm CPUS=$(nproc)
$ make -C payloads/coreinfo
$ make menuconfig
select 'Mainboard' menu
Beside 'Mainboard vendor' should be '(Emulation)'
Beside 'Mainboard model' should be 'QEMU armv7 (vexpress-a9)'
select 'Payload' menu
select 'Add a Payload'
choose 'An Elf executable payload'
select 'Payload path and filename'
enter 'payloads/coreinfo/build/coreinfo.elf'
$ make
…..(omitted).....
W: Written area will abut bottom of target region: any unused space will keep its current contents
CBFS fallback/romstage
CBFS fallback/ramstage
CBFS config
CBFS revision
CBFS fallback/payload
INFO: Performing operation on 'COREBOOT' region...
make: *** [check-ramstage-overlaps] Error 1
PR Updated by Patrick Rudolph over 7 years ago
coreinfo is x86 only and is compiled using the i386-gcc.
Trying to use it on arm machine causes this issue.
AD Updated by Asami Doi over 7 years ago
You're right. I made a mistake to compile payload as 32-bit x86 architecture.
So, I created an executable elf file for 32-bit ARM and added coreboot.rom as a payload.
However, "Payload not loaded." happens when I execute on qemu-system-arm.
I'm investigating why I cannot execute coreboot.rom with an ARM elf file and this issue should be closed after solve it.
The reason why "Payload not loaded" happens is because the configuration of libpayload was not enough.
The load address of a payload should be placed the RAM place where anyone can use. You can define the load address by CONFIG_LP_BASE_ADDRESS in the libpayload directory.
This issue should be closed because I updated a sample Makefile and created a configuration. We can currently build an ARM payload with libpayload for QEMU.
Please see this CL for more information: https://review.coreboot.org/c/coreboot/+/33287
- Status changed from New to Closed
