Bug #179
closed
FH
coreboot Makefile breaks when the path to the coreboot directory contains spaces
Bug #179: coreboot Makefile breaks when the path to the coreboot directory contains spaces
Added by Felix Held almost 8 years ago. Updated almost 7 years ago.
Closed
build system
11/10/2018
HT Updated by HCL technologies about 7 years ago Actions #1
As per our understanding this happens due to the CURDIR in the top level Makefile, which treats space as separator for words.
It reads till the first space in the directory path( First word), does not count the space and shows only the path till the space occurs.
Prior to CURDIR, PWD (used in most shell env) used instead in the Makefile, and later it was changed to CURDIR to make the build system more robust ,as it was not possible to use PWD in every environment.
Therefore, from our perspective we should provide an appropriate error message i.e "Path to the main directory cannot contain spaces" which can point the user for the exact error and stop further execution.
Please refer https://review.coreboot.org/c/coreboot/+/35434
HT Updated by HCL technologies almost 7 years ago Actions #2
As the possible fix/alternative has been merged as above check-in. We can now change the status of this issue as close.
PM Updated by Paul Menzel almost 7 years ago Actions #3
