Bug #132
closed
PM
MR
Problem with `lint-stable` when changing mode of file
Bug #132:
Resolved
Martin Roth
07/24/2017
Running chmod +x on a file, which doesn’t have this mode before, committing this fails, with the error below.
Makefile.inc:559: recipe for target 'lint-stable' failed
make: *** [lint-stable] Error 1
ERROR: Does not appear to be a unified-diff format patch
MR Updated by Martin Roth about 9 years ago
- Assignee set to Martin Roth
I'll take a look. There aren't any files being changed, so there's no update diff for it to handle. I know this would be a problem for checkpatch, but I'm not sure which other lint tools would have the issue.
This was actually a checkpatch error when running the pre-commit githook, but since checkpatch was erroring out, it didn't say that it was checkpatch.
Fixed with https://review.coreboot.org/20781
After the patch is committed, users will need to re-run 'make gitconfig' to get the change.
