Bug #111
closed
PW PM
intelmetool: compiler warning
Bug #111: intelmetool: compiler warning
Added by Paul Wise about 9 years ago. Updated about 9 years ago.
Resolved
userspace utilities
05/04/2017
100%
1.00 h
I get a compiler warning when building intelmetool. I'm using GCC 6.3.0-14 from Debian stretch.
cc -O0 -g -Wall -W -Wno-unused-parameter -Wno-unused-but-set-variable -Wno-sign-compare -Wno-unused-function   -c -o intelmetool.o intelmetool.c
intelmetool.c: In function ‘dump_me_memory’:
intelmetool.c:85:45: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
  dump = map_physical_exact((off_t)me_clone, (void *)me_clone, 0x2000000);
PM Updated by Paul Menzel about 9 years ago Actions #1
  • Status changed from New to Response Needed
  • Assignee set to Paul Menzel
  • % Done changed from 0 to 90
  • Estimated time set to 1.00 h
Thank you for reporting this issue. Please note, that this only manifests itself with 64-bit userspace.
Change Id8d778e97090668ad9308a82b44c6b2b599fd6c3 should fix the problem.
PW Updated by Paul Wise about 9 years ago Actions #2
This change looks good to me.
I note that 64-bit PC architectures are more popular than 32-bit these days and some distributions are even planning to drop 32-bit architectures.
PM Updated by Paul Menzel about 9 years ago Actions #3
  • Status changed from Response Needed to Resolved
The change was submitted.
PM Updated by Paul Menzel about 9 years ago Actions #4
  • % Done changed from 90 to 100
