Bug #660
open
WS
CFR options showup, can be adjusted, can be saved but don't have effect?
Bug #660: CFR options showup, can be adjusted, can be saved but don't have effect?
Added by Walter Sonius 3 months ago. Updated 3 months ago.
New
chipset configuration
08/04/2026
Have build several times CFR options into multiple snd_ivb/haswell/skylake ports over the past few months and cannot remember one time it worked besides from being that the menu options showup. Its settings can be adjusted and saved and after reboot it shows that they are saved but have no effect.
For instance Dell Vostro 270 (Ivy Bridge) CB:89412, using the following additions:
Makefile.c
ramstage-$(CONFIG_DRIVERS_OPTION_CFR) += cfr.c
cfr.c
/* SPDX-License-Identifier: GPL-2.0-only */
#include <boot/coreboot_tables.h>
#include <console/cfr.h>
#include <drivers/option/cfr_frontend.h>
#include <northbridge/intel/sandybridge/cfr.h>
#include <southbridge/intel/bd82x6x/cfr.h>
// copy pasted ht section in src/northbridge/intel/sandybridge/cfr.h
//static const struct sm_object hyper_threading = SM_DECLARE_BOOL({
//      .opt_name       = "hyper_threading",
//      .ui_name        = "Hyper-Threading",
//      .ui_helptext    = "Enable or disable Hyper-Threading",
//      .default_value  = true,
static struct sm_obj_form system = {
        .ui_name = "System",
        .obj_list = (const struct sm_object *[]){&debug_level, &gfx_uma_size,
                                                 &me_state,
                                                 &me_state_prev, &nmi,
                                                 &hyper_threading, &sata_mode,
                                                 NULL},
static struct sm_obj_form power = {
        .ui_name = "Power",
        .obj_list = (const struct sm_object *[]){&power_on_after_fail, NULL},
static struct sm_obj_form *sm_root[] = {&system, &power, NULL};
void mb_cfr_setup_menu(struct lb_cfr *cfr_root)
        cfr_write_setup_menu(cfr_root, sm_root);
Kconfig
select DRIVERS_OPTION_CFR_ENABLED if PAYLOAD_EDK2 && SMMSTORE
If payload is EDK2(MrChromebox2605) on coreboot 26.06-645-gc6c871909a12-dirty and driver SMMSTORE is enabled so Secureboot is also included it is possible to enable DRIVERS_OPTION_CFR which auto enables DRIVERS_EFI_VARIABLE_STORE.
Do you also need to specify "Option backend to use" like CMOS, since after I enabled CFR driver as build option it shows a additional make menu option in this section which I have tried with and without.
USE_UEFI_VARIABLE_STORE
( ) Use UEFI variable-store in SPI flash as option backend
Have tried adjusting debug_level, hyper_threading, power_on_after_fail and they all remain the same.
Any hints, the cmos options do work for this board though?
WS Updated by Walter Sonius 3 months ago Actions #1
reserved
NC Updated by Nicholas Chin 3 months ago Actions #2
Yes, UEFI variable store needs to be enabled as the option backend for it to work (CONFIG_USE_UEFI_VARIABLE_STORE)
Maybe try adding some debug messages to drivers/efi/option.c:get_uint_option() and see when it gets called and if it's reading the options correctly?
WS Updated by Walter Sonius 3 months ago Actions #3
It works now... for the Acer TravelMate P-633M CB:91512, perhaps need to do a make distclean for the Dell Vostro A270 aswell The new EDK2 graphical UI scale setting also gets saved.
Will keep this updated for the Dell, if it still fails will try some debug printk(BIOS_SPEW, "Failed cfr setting at x line?\n")?
WS Updated by Walter Sonius 3 months ago Actions #4
Seems to be FIXED for Dell Vostro 270 aswell, tested debug_level , sata_mode and power_on_after_fail only noticed the last with Keep / last state won't come back powered on while that did work with CMOS in the past. It however does lit the ethernet leds when power gets restored in this keep option which doesn't happen on the Disabled / always off S5 option...
Please CLOSE.
