Bug #655
open
DW
m920q fails to do_global_reset() after 25.06
Bug #655: m920q fails to do_global_reset() after 25.06
Added by Dawid Wrobel 4 months ago. Updated about 2 months ago.
In Progress
board support
06/30/2026
m920q
I attempted to upgrade 25.06 to 26.06 and the system fails to reboot. Serial console shows:
[DEBUG]  Starting cbfs_boot_device
[INFO ]  CBFS: Found 'fallback/payload' @0x186200 size 0x16f875 in mcache @0x89ced394
[DEBUG]  Checking segment from ROM address 0xff91722c
[DEBUG]  Checking segment from ROM address 0xff917248
[DEBUG]  Loading segment from ROM address 0xff91722c
[DEBUG]    code (compression=1)
[DEBUG]    New segment dstaddr 0x00800000 memsize 0xa00000 srcaddr 0xff917264 filesize 0x16f83d
[DEBUG]  Loading Segment: addr: 0x00800000 memsz: 0x0000000000a00000 filesz: 0x000000000016f83d
[DEBUG]  using LZMA
[INFO ]  Timestamp - starting LZMA decompress (ignore for x86): 12649673533
[INFO ]  Timestamp - finished LZMA decompress (ignore for x86): 13078746300
[DEBUG]  Loading segment from ROM address 0xff917248
[DEBUG]    Entry Point 0x00803ac5
[DEBUG]  BS: BS_PAYLOAD_LOAD run times (exec / console): 230 / 91 ms
[INFO ]  Timestamp - calling FspNotify(ReadyToBoot): 13124864519
[INFO ]  Timestamp - returning from FspNotify(ReadyToBoot): 13157210020
[DEBUG]  GLOBAL RESET!
[INFO ]  global_reset() called!
[DEBUG]  HECI: Global Reset(Type:1) Command
[DEBUG]  HECI: Global Reset success!
Everything seems just fine here, except the reset actually does not happen at this point, but it did with 25.06.
This most likely has something to do with changes made do_global_reset() sometime after 25.06:
~/coreboot-builder-scripts/m920q/build# git log 25.06..25.12 --oneline --   src/soc/intel/cannonlake/   src/mainboard/lenovo/m920q/   src/soc/intel/common/block/cse/
7f93e2fe29 soc/intel/*: Add CFR option to enable/disable the Intel iGPU
d5ea359347 soc/intel/**/cfr.h: Fix typo of "ACPI" in UI help text
84a4cdc6a5 soc/intel/*: Only skip PMC fallback on successful CSE reset
4f52ca6ba6 soc/intel/common/cse: Return usable error codes
50a59d4464 device: Add Kconfig to prepare for reworked verb table implementation
fbc2d76ab3 soc/intel/*: Select 'DRAM_SUPPORT_DDRx' as appropriate
da49da6c82 soc/intel: Add Arrow Lake-S/HX IDs
626c5364b8 tree: Use boolean for PcieRpSlotImplemented[]
and the candidate that stands out is 84a4cdc6a5:
commit 84a4cdc6a533dc909a25fde25d99dca13ad2d28c
Author: Sean Rhodes <sean@starlabs.systems>
Date:   Sat Nov 29 20:41:03 2025 +0000
    cse_request_global_reset() returns CSE_TX_RX_SUCCESS on success. Make
    do_global_reset() explicatly check for that, and fall back CF9 for any
    other value.
    Test=Disable and enable the Intel ME on starbook_mtl and verify the
    system actually resets, rather than hanging.
    Change-Id: I4c3fb7995bca8e7fe3793b9aee021e4004ace933
    Signed-off-by: Sean Rhodes <sean@starlabs.systems>
    Reviewed-on: https://review.coreboot.org/c/coreboot/+/90273
    Tested-by: build bot (Jenkins) <no-reply@coreboot.org>
    Reviewed-by: Matt DeVillier <matt.devillier@gmail.com>
diff --git a/src/soc/intel/alderlake/reset.c b/src/soc/intel/alderlake/reset.c
index bc5815ac7a..3c13f6dfe5 100644
--- a/src/soc/intel/alderlake/reset.c
+++ b/src/soc/intel/alderlake/reset.c
@@ -8,7 +8,7 @@
 void do_global_reset(void)
        /* Ask CSE to do the global reset */
-       if (cse_request_global_reset())
+       if (cse_request_global_reset() == CSE_TX_RX_SUCCESS)
                return;
        /* global reset if CSE fail to reset */
diff --git a/src/soc/intel/cannonlake/reset.c b/src/soc/intel/cannonlake/reset.c
--- a/src/soc/intel/cannonlake/reset.c
+++ b/src/soc/intel/cannonlake/reset.c
@@ -8,7 +8,7 @@
                return;
diff --git a/src/soc/intel/elkhartlake/reset.c b/src/soc/intel/elkhartlake/reset.c
and 4f52ca6ba6:
commit 4f52ca6ba666dbebc7cc4e299d7b49796ac297d8
Date:   Sat Nov 29 20:37:06 2025 +0000
    Currently, cse_request_reset() returns 0 if the reset type is
    unsupported or CSE isn’t ready. This is the same as
    CSE_TX_RX_SUCCESS, which makes failures impossible to detect.
    Return CSE_TX_ERR_INPUT or CSE_TX_ERR_CSE_NOT_READY respectively,
    so we can detect errors.
    Change-Id: Idede7342157901946ba62ba6fcda6f304a4a3fd0
    Reviewed-on: https://review.coreboot.org/c/coreboot/+/90272
    Reviewed-by: Jérémy Compostella <jeremy.compostella@intel.com>
diff --git a/src/soc/intel/common/block/cse/cse.c b/src/soc/intel/common/block/cse/cse.c
index 1f519312ce..d02bb85b37 100644
--- a/src/soc/intel/common/block/cse/cse.c
+++ b/src/soc/intel/common/block/cse/cse.c
@@ -737,12 +737,12 @@ static int cse_request_reset(enum rst_req_type rst_type)
        if (!(rst_type == GLOBAL_RESET || rst_type == CSE_RESET_ONLY)) {
                printk(BIOS_ERR, "HECI: Unsupported reset type is requested\n");
-               return 0;
+               return CSE_TX_ERR_INPUT;
        if (!cse_is_global_reset_allowed() || !is_cse_enabled()) {
                printk(BIOS_ERR, "HECI: CSE does not meet required prerequisites\n");
-               return 0;
+               return CSE_TX_ERR_CSE_NOT_READY;
        heci_reset();
AP Updated by Angel Pons about 2 months ago Actions #1
  • Related links updated (diff)
CNL/CFL reference code always falls back to PCH reset after requesting a global reset via CSE. If the global reset request was successful, the code waits for 1 second to give CSE time to actually perform the reset.
https://review.coreboot.org/94486 should take care of this.
