Maintenance #648
openYour Gerrit instance's e-mail server is listed as spam (in AScam's SuperBlock).
As github.com/anonaddy/anonaddy/issues/869#issuecomment-4533093077 explains, your Gerrit instance's IP address is listed as spam, at multirbl.valli.org/lookup/78.46.105.101.html. Specifically, on at least netblockbl.spamgrouper.to, and superblock.ascams.com, which states:
It becomes more complicated if your IP resource score is too high as this means that there are additional complications. superblock.ascams.com contains no false positives. “your” resource or resource ranges were responsible for scams, spam, phish, cyber crime, etc. and if it is your range, it may also means that you do not react, accept or manage your abuse (or accept emailed complaints… You want to SEND email but you do not want to manage via email. etc.)
Removal: It is easy to apply for removal and be removed if the resource score is lowered. You need to lower your IP resource score…
Check list for sending email/web servers:The listing is younger than 12 months. Old listings means that the resource manager does not and did not care about abuse reports or listings on ascams.com. The resource score will also be higher as listed resources gain points for each year of listing.
This has prevented me receiving mail, from your Gerrit instance, in the past.
Files
RB Updated by Roke Beedell 6 months ago
- Subject changed from Your Gerrit instance's e-mail server is listed, as spam (in AScam's SuperBlock). to Your Gerrit instance's e-mail server is listed as spam (in AScam's SuperBlock).
