Bug #53
closed
PK
RW EC image for nyan_big built with Coreboot hangs
Bug #53: RW EC image for nyan_big built with Coreboot hangs
Added by Paul Kocialkowski over 10 years ago. Updated about 10 years ago.
Closed
05/08/2016
The RW EC image built within the Coreboot build system for nyan_big does not work correctly on the current git master. This is when building a full ChromeOS flash image.
The problem seems to be watchdog-related, as shown in the log:
[1.440086 hash done 5d975c3ce90d799d616caa75e0cfe6a8cca3fe1e3af1d3b7ded63d1e66cf235d]
[1.528157 HC 0x87]
[1.543803 HC 0x17]
[1.624638 HC 0x87]
[1.880736 HC 0x0b]
[1.885350 HC 0x02]
[1.893408 HC 0x8f]
[1.894333 HC 0x17]
[1.895840 HC 0x02]
[1.903151 HC 0x2a]
[1.955266 HC 0xd2]
[1.955518 Executing host reboot command 2]
[1.956211 Jumping to image RW]
[1.963886 UART initialized after sysjump]
[Image: RW, big_v1.1.4330-388a7fa 2016-02-10 12:44:16 paulk@aldrin]
[1.966653 Inits done]
[1.966947 Wait for battery stabilized during 1000000]
### WATCHDOG PC=08019d3e / LR=0801a07d / pSP=200015d8 (task 0) ###
Time:     0x00000000002e16ce us
Deadline: 0x00000000001eca5a ->   -1.002612 s from now
Active timers:
Task Ready Name         Events      Time (s)  StkUsed
   0 R << idle >>       00000000    0.024966  256/256
   1 R HOOKS            80000000    0.000836  640/640
   2   CHARGER          00000000    0.000000   64/640
   3   CHIPSET          00000000    0.000000   64/640
   4   HOSTCMD          00000000    0.000000   64/488
   5   CONSOLE          00000000    0.000000   64/488
   6   KEYSCAN          00000000    0.000000   64/488
--- UART initialized after reboot ---
[Reset cause: reset-pin watchdog]
Files
ec-rw.txt (1.18 KB) ec-rw.txt Paul Kocialkowski, 05/08/2016 04:29 PM
PK Updated by Paul Kocialkowski over 10 years ago Actions #1
This breaks the whole boot process as vboot waits for the EC to reply. Eventually, it triggers a reboot after timeout, going endlessly in a reboot cycle.
PK Updated by Paul Kocialkowski over 10 years ago Actions #2
PK Updated by Paul Kocialkowski over 10 years ago Actions #3
Disabling EC software sync in the GBB flags works around the issue, but a proper fix would be to fix the EC code.
PK Updated by Paul Kocialkowski over 10 years ago Actions #4
  • Description updated (diff)
PK Updated by Paul Kocialkowski about 10 years ago Actions #5
It looks like CrOS EC TOT runs fine on big now, so we can close this.
