Support #464
open
AP
Writes to AM29LV040B with -p satasii work properly
Support #464: Writes to AM29LV040B with -p satasii work properly
Added by Alex Perez over 3 years ago.
New
02/22/2023
When flashing the AM29LV040B with -p satasii (attached to a PCI SATA card) using the latest git checkout, writes work fine. Write Protect does NOT work. I've also reported this via e-mail to , as per the command-line recommendation.
No data to display
