Support #349
open
RG
support to add WINBOND W25Q256JW SPIROM
Support #349: support to add WINBOND W25Q256JW SPIROM
Added by ritul guru over 4 years ago.
New
board support
04/12/2022
I am trying to add support for WINBOND SPI FLASH part W25Q256JW (0x6019).
tried adding below entry in winbond.c, is there any other changes required to enable this part to boot from?
    /* W25Q256JW */
    .id[0]              = 0x6019,
    .nr_sectors_shift       = 13,
    .fast_read_dual_output_support  = 1,
    .fast_read_dual_io_support  = 1,
    .protection_granularity_shift   = 16,
    .bp_bits            = 4,
No data to display
