Support #324
opensamsung r580
model: np r580 js09
cpu: Intel(R) Core(TM) i3 CPU M 330
north bridge : Intel SLGZS (BD82HM55)
gpu: GeForce GT 330M
mother board: Bremen-M rev:1.3(100321)-8
lspci -tvnn
-+-[0000:3f]-+-00.0 Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers [8086:2c62]
| +-00.1 Intel Corporation Core Processor QuickPath Architecture System Address Decoder [8086:2d01]
| +-02.0 Intel Corporation Core Processor QPI Link 0 [8086:2d10]
| +-02.1 Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 [8086:2d11]
| +-02.2 Intel Corporation 1st Generation Core i3/5/7 Processor Reserved [8086:2d12]
| -02.3 Intel Corporation 1st Generation Core i3/5/7 Processor Reserved [8086:2d13]
-[0000:00]-+-00.0 Intel Corporation Core Processor DRAM Controller [8086:0044]
+-01.0-[02]--+-00.0 NVIDIA Corporation GT216M [GeForce GT 330M] [10de:0a29]
| -00.1 NVIDIA Corporation GT216 HDMI Audio Controller [10de:0be2]
+-1a.0 Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller [8086:3b3c]
+-1b.0 Intel Corporation 5 Series/3400 Series Chipset High Definition Audio [8086:3b56]
+-1c.0-[03-04]----00.0 Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) [168c:002b]
+-1c.2-[05-06]--
+-1c.3-[07-08]----00.0 Marvell Technology Group Ltd. Yukon Optima 88E8059 [PCIe Gigabit Ethernet Controller with AVB] [11ab:4381]
+-1d.0 Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller [8086:3b34]
+-1e.0-[09]--
+-1f.0 Intel Corporation HM55 Chipset LPC Interface Controller [8086:3b09]
+-1f.2 Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller [8086:3b29]
-1f.3 Intel Corporation 5 Series/3400 Series Chipset SMBus Controller [8086:3b30]
flashrom -p internal -V
flashrom v1.2 on Linux 5.15.5-zen1-1-zen (x86_64)
flashrom is free software, get the source code at https://flashrom.org
flashrom was built with libpci 3.6.4, GCC 9.3.0, little endian
Command line (3 args): flashrom -p internal -V
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Initializing internal programmer
/sys/class/mtd/mtd0 does not exist
No coreboot table found.
Using Internal DMI decoder.
DMI string chassis-type: "Laptop"
Laptop detected via DMI.
DMI string system-manufacturer: "SAMSUNG ELECTRONICS CO., LTD."
DMI string system-product-name: "R580/R590 "
DMI string system-version: "Not Applicable"
DMI string baseboard-manufacturer: "SAMSUNG ELECTRONICS CO., LTD."
DMI string baseboard-product-name: "R580/R590 "
DMI string baseboard-version: "Not Applicable"
Found chipset "Intel HM55" with PCI ID 8086:3b09.
Enabling flash write... Root Complex Register Block address = 0xfed1c000
Error accessing ICH RCRB, 0x4000 bytes at 0x00000000fed1c000
/dev/mem mmap failed: Operation not permitted
FAILED!
FATAL ERROR!
Error: Programmer initialization failed.
II Updated by Ivan Ivanov almost 5 years ago
What is a problem that you would like to report?
- That your laptop is not supported by coreboot BIOS?
- Or that the flashrom's internal mode is not working for you?
If 2), boot with "iomem=relaxed" Linux kernel option and try again.
KK Updated by kostya kuznetsov almost 5 years ago
- yes not supported(s chego nachat esli proshe)
`flashrom -p internal -V
GCS = 0xc61: BIOS Interface Lock-Down: enabled, Boot BIOS Straps: 0x3 (SPI)
Top Swap: not enabled
0x7fffffff/0x7fffffff FWH IDSEL: 0x0
0x7fffffff/0x7fffffff FWH IDSEL: 0x1
0x7fffffff/0x7fffffff FWH IDSEL: 0x2
0x7fffffff/0x7fffffff FWH IDSEL: 0x4
0x7fffffff/0x7fffffff FWH IDSEL: 0x5
0x7fffffff/0x7fffffff FWH IDSEL: 0x6
0x7fffffff/0x7fffffff FWH IDSEL: 0x7
0x7fffffff/0x7fffffff FWH decode enabled
Maximum FWH chip size: 0x200000 bytes
SPI Read Configuration: prefetching disabled, caching enabled,
BIOS_CNTL = 0x01: BIOS Lock Enable: disabled, BIOS Write Enable: enabled
SPIBAR = 0x00007f4fd2e1f000 + 0x3800
0x04: 0x6008 (HSFS)
HSFS: FDONE=0, FCERR=0, AEL=0, BERASE=1, SCIP=0, FDOPSS=1, FDV=1, FLOCKDN=0
Programming OPCODES... done
0x06: 0x0000 (HSFC)
HSFC: FGO=0, FCYCLE=0, FDBC=0, SME=0
0x50: 0x00000a0b (FRAP)
BMWAG 0x00, BMRAG 0x00, BRWA 0x0a, BRRA 0x0b
0x54: 0x00000000 FREG0: Flash Descriptor region (0x00000000-0x00000fff) is read-only.
0x58: 0x03ff0200 FREG1: BIOS region (0x00200000-0x003fffff) is read-write.
0x5C: 0x01ff0004 FREG2: Management Engine region (0x00004000-0x001fffff) is locked.
0x64: 0x00030001 FREG4: Platform Data region (0x00001000-0x00003fff) is locked.
Not all flash regions are freely accessible by flashrom. This is most likely
due to an active ME. Please see https://flashrom.org/ME for details.
At least some flash regions are read protected. You have to use a flash
layout and include only accessible regions. For write operations, you'll
additionally need the --noverify-all switch. See manpage for more details.
0x90: 0x00 (SSFS)
SSFS: SCIP=0, FDONE=0, FCERR=0, AEL=0
0x91: 0xf84200 (SSFC)
SSFC: SCGO=0, ACS=0, SPOP=0, COP=0, DBC=2, SME=0, SCF=0
0x94: 0x5006 (PREOP)
0x96: 0x463b (OPTYPE)
0x98: 0x05200302 (OPMENU)
0x9c: 0xc79f0190 (OPMENU+4)
0xa0: 0x00000000 (BBAR)
0xc4: 0x00802005 (LVSCC)
LVSCC: BES=0x1, WG=1, WSR=0, WEWS=0, EO=0x20, VCL=1
0xc8: 0x00002005 (UVSCC)
UVSCC: BES=0x1, WG=1, WSR=0, WEWS=0, EO=0x20
0xd0: 0x00000000 (FPB)
OK.
The following protocols are supported: SPI.
Probing for AMIC A25L010, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L016, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L020, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L032, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L040, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L05PT, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L05PU, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L080, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L10PT, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L10PU, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L16PT, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L16PU, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L20PT, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L20PU, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L40PT, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L40PU, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L512, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25L80P, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25LQ032/A25LQ32A, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25LQ16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for AMIC A25LQ64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF021, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF021A, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF041A, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF081, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF081A, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF161, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF321, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF321A, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DF641(A), 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DL081, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DL161, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25DQ161, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25F1024(A), 128 kB: probe_spi_at25f: id1 0xff, id2 0xff
Probing for Atmel AT25F2048, 256 kB: probe_spi_at25f: id1 0xff, id2 0xff
Probing for Atmel AT25F4096, 512 kB: probe_spi_at25f: id1 0xff, id2 0xff
Probing for Atmel AT25F512, 64 kB: probe_spi_at25f: id1 0xff, id2 0xff
Probing for Atmel AT25F512A, 64 kB: probe_spi_at25f: id1 0xff, id2 0xff
Probing for Atmel AT25F512B, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25FS010, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25FS040, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25SF041, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25SF081, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25SF161, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25SF321, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT25SL128A, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT26DF041, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT26DF081A, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT26DF161, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT26DF161A, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT26F004, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45CS1282, 16896 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB011D, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB021D, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB041D, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB081D, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB161D, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB321C, 4224 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB321D, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB321E, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel AT45DB642D, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ESI ES25P16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ESI ES25P40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ESI ES25P80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ESMT F25L008A, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ESMT F25L32PA, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B05, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B05T, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B10T, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B16T, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B20T, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B32T, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B40T, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B64T, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25B80T, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25F05, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25F10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25F16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25F20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25F32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25F40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25F64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25F80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25P05, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25P10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25P16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25P20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25P32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25P40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25P64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25P80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25Q128, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25Q16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25Q32(A/B), 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25Q40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25Q64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25Q80(A), 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25QH128, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25QH16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25QH32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25QH64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25S10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25S16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25S20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25S32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25S40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25S64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon EN25S80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25B128B/GD25Q128B, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25LQ128C/GD25LQ128D, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25LQ16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25LQ32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25LQ40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25LQ64(B), 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25LQ80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q127C/GD25Q128C, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q16(B), 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q20(B), 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q256D, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q32(B), 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q40(B), 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q512, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q64(B), 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25Q80(B), 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25T80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25VQ16C, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25VQ21B, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25VQ40C, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25VQ41B, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for GigaDevice GD25VQ80C, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ISSI IS25LP064, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ISSI IS25LP128, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ISSI IS25LP256, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ISSI IS25WP032, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ISSI IS25WP064, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ISSI IS25WP128, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ISSI IS25WP256, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Intel 25F160S33B8, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Intel 25F160S33T8, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Intel 25F320S33B8, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Intel 25F320S33T8, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Intel 25F640S33B8, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Intel 25F640S33T8, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX23L12854, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX23L1654, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX23L3254, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX23L6454, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L1005(C)/MX25L1006E, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L12805D, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L12835F/MX25L12845E/MX25L12865E, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L1605, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L1605A/MX25L1606E/MX25L1608E, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L1605D/MX25L1608D/MX25L1673E, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L1635D, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L1635E, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L2005(C)/MX25L2006E, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L25635F/MX25L25645G, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L3205(A), 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Found Macronix flash chip "MX25L3205(A)" (4096 kB, SPI) mapped at physical address 0x00000000ffc00000.
Chip status register is 0x00.
Chip status register: Status Register Write Disable (SRWD, SRP, ...) is not set
Chip status register: Bit 6 is not set
Chip status register: Bit 5 is not set
Chip status register: Block Protect 2 (BP2) is not set
Chip status register: Block Protect 1 (BP1) is not set
Chip status register: Block Protect 0 (BP0) is not set
Chip status register: Write Enable Latch (WEL) is not set
Chip status register: Write In Progress (WIP/BUSY) is not set
Probing for Macronix MX25L3205D/MX25L3208D, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Found Macronix flash chip "MX25L3205D/MX25L3208D" (4096 kB, SPI) mapped at physical address 0x00000000ffc00000.
Chip status register: Block Protect 3 (BP3) is not set
Probing for Macronix MX25L3206E/MX25L3208E, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Found Macronix flash chip "MX25L3206E/MX25L3208E" (4096 kB, SPI) mapped at physical address 0x00000000ffc00000.
Probing for Macronix MX25L3235D, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L3273E, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Found Macronix flash chip "MX25L3273E" (4096 kB, SPI) mapped at physical address 0x00000000ffc00000.
Probing for Macronix MX25L4005(A/C)/MX25L4006E, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L512(E)/MX25V512(C), 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L6405, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L6405D, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L6406E/MX25L6408E, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L6436E/MX25L6445E/MX25L6465E/MX25L6473E/MX25L6473F, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L6495F, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25L8005/MX25L8006E/MX25L8008E/MX25V8005, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25R6435F, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25U12835F, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25U1635E, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25U25635F, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25U3235E/F, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25U51245G, 65536 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25U6435E/F, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX25U8032E, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix MX66L51235F/MX25L51245G, 65536 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P05, 64 kB: Ignoring RES in favour of RDID.
Probing for Micron/Numonyx/ST M25P05-A, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P10, 128 kB: Ignoring RES in favour of RDID.
Probing for Micron/Numonyx/ST M25P10-A, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P128, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P20-old, 256 kB: Ignoring RES in favour of RDID.
Probing for Micron/Numonyx/ST M25P32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P40-old, 512 kB: Ignoring RES in favour of RDID.
Probing for Micron/Numonyx/ST M25P64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25P80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PE10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PE16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PE20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PE40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PE80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PX16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PX32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PX64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M25PX80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M45PE10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M45PE16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M45PE20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M45PE40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST M45PE80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q00A..1G, 131072 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q00A..3G, 131072 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q016, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q032..1E, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q032..3E, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q064..1E, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q064..3E, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q128..1E, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q128..3E, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q256..1E, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q256..3E, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q512..1G, 65536 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron/Numonyx/ST N25Q512..3G, 65536 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QL01G, 131072 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QU01G, 131072 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QL02G, 262144 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QU02G, 262144 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QU128, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QL128, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QL256, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QU256, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QL512, 65536 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Micron MT25QU512, 65536 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Nantronics N25S10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Nantronics N25S16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Nantronics N25S20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Nantronics N25S40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Nantronics N25S80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LD010(C), 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LD020(C), 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LD040(C), 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LD256C, 32 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LD512(C), 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LQ016, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LQ020, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LQ032C, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LQ040, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LQ080, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LV010, 128 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for PMC Pm25LV010A, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LV016B, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LV020, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LV040, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LV080B, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC Pm25LV512(A), 64 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for SST SST25LF020A, 256 kB: probe_spi_rems: id1 0xc2, id2 0x15
Probing for SST SST25LF040A, 512 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for SST SST25LF080(A), 1024 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for SST SST25VF010(A), 128 kB: probe_spi_rems: id1 0xc2, id2 0x15
Probing for SST SST25VF016B, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25VF020, 256 kB: probe_spi_rems: id1 0xc2, id2 0x15
Probing for SST SST25VF020B, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25VF032B, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25VF040, 512 kB: probe_spi_rems: id1 0xc2, id2 0x15
Probing for SST SST25VF040B, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25VF040B.REMS, 512 kB: probe_spi_rems: id1 0xc2, id2 0x15
Probing for SST SST25VF064C, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25VF080B, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25VF512(A), 64 kB: probe_spi_rems: id1 0xc2, id2 0x15
Probing for SST SST25WF010, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25WF020, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25WF020A, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25WF040, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25WF040B, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25WF080, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25WF080B, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST25WF512, 64 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST26VF016B(A), 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST26VF032B(A), 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST SST26VF064B(A), 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ST M95M02, 256 kB: probe_spi_st95: id1 0xff, id2 0xffff
Probing for Sanyo LE25FU106B, 128 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for Sanyo LE25FU206, 256 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for Sanyo LE25FU206A, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Sanyo LE25FU406B, 512 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for Sanyo LE25FU406C/LE25U40CMC, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Sanyo LE25FW106, 128 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for Sanyo LE25FW203A, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Sanyo LE25FW403A, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Sanyo LE25FW406A, 512 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for Sanyo LE25FW418A, 512 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for Sanyo LE25FW806, 1024 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for Sanyo LE25FW808, 1024 kB: probe_spi_res2: id1 0x15, id2 0x15
Probing for Spansion S25FL004A, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL008A, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL016A, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL032A/P, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL064A/P, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL116K/S25FL216K, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL127S-256kB, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL127S-64kB, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL128P......0, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL128P......1, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL128S......0, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL128S......1, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL129P......0, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL129P......1, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL132K, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL164K, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL204K, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL208K, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL256S......0, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Spansion S25FL512S, 65536 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25P16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25P32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25P80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q128.V, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q128.V..M, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q128.W, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q128.JW.DTR, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q16.V, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q16.W, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q20.W, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q256.V, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q256JV_M, 32768 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q32.V, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q32.W, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q40.V, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q40BW, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q40EW, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q64.V, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q64.W, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q80.V, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q80BW, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25Q80EW, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25X10, 128 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25X16, 2048 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25X20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25X32, 4096 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25X40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25X64, 8192 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond W25X80, 1024 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Zetta Device ZD25D20, 256 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Zetta Device ZD25D40, 512 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Unknown SFDP-capable chip, 0 kB: No SFDP signature found.
Probing for AMIC unknown AMIC SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Atmel unknown Atmel SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Eon unknown Eon SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Macronix unknown Macronix SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for PMC unknown PMC SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for SST unknown SST SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for ST unknown ST SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Sanyo unknown Sanyo SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Winbond unknown Winbond (ex Nexcom) SPI chip, 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Generic unknown SPI chip (RDID), 0 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2016
Probing for Generic unknown SPI chip (REMS), 0 kB: probe_spi_rems: id1 0xc2, id2 0x15
Multiple flash chip definitions match the detected chip(s): "MX25L3205(A)", "MX25L3205D/MX25L3208D", "MX25L3206E/MX25L3208E", "MX25L3273E"
Please specify which chip definition to use with the -c option.
Restoring MMIO space at 0x7f4fd2e228a0
Restoring MMIO space at 0x7f4fd2e2289c
Restoring MMIO space at 0x7f4fd2e22898
Restoring MMIO space at 0x7f4fd2e22896
Restoring MMIO space at 0x7f4fd2e22894
Restoring PCI config space for 00:1f:0 reg 0xdc
ME Updated by Michael Edelmann almost 5 years ago
looks like your flash is RO. if there is an option for BIOS write protection in your BIOS settings, disable it.
if there is none or it still won't work, try flashing externally (e.g. with a raspberry pi), and first of all back up externally too. compare your 2 backups, and if they aren't identical, use the external dump for any tinkering you are doing.
additionally need the --noverify-all switch. See manpage for more details.looks like your flash is RO. if there is an option for BIOS write protection in your BIOS settings, disable it.
I don't have such an option, you mean that I should flash my native BIOS through the programmer?, you can learn more about what to do, since I'm a beginner
i update full logs https://github.com/SPRATAY/coreboot
