Bug #24
closed
x60: fn_ctrl_swap does not work
Added by Gordon Quad over 8 years ago. Updated almost 7 years ago.
Resolved
01/13/2016
How to reproduce:
./nvramtool -w fn_ctrl_swap=Enable
reboot
Fn and Ctrl are not swapped even in coreboot payload (grub2).
coreboot-6b2d83c3526157582fb28776cca2bed0bedfe4e9
grub2 payload from libreboot build
Actions #1
Updated by Alexander Couzens about 8 years ago
  • Assignee set to Alexander Couzens
Actions #2
I can confirm it with coreboot ET4000 4.3-424-g7760261
Actions #3
my old oem bios doesn't have an option for that. it might possible, that the EC isn't supporting the fn_swap on this device.
i'll update to the latest oem bios to see if a newer version supports it.
Actions #4
even with the newest option, the oem bios doesn't have such option.
The x60 doesnt support this option, we should remove this nvram option from x60.
Actions #5
Updated by Nico Huber almost 7 years ago
  • Status changed from In Progress to Resolved
  • Assignee changed from Alexander Couzens to Nico Huber
Will push a patch to remove the option from X60/T60 once gerrit is online again.
Also available in: Atom PDF
