Bug #223
open
VD
Errors compiling: No Video on Thinkpad x220 with 4.10
Bug #223: Errors compiling: No Video on Thinkpad x220 with 4.10
Added by Vasile Dan over 7 years ago.
New
chipset configuration
07/30/2019
I'm having trouble compiling the new version for the Thinkpad x220. At first it throws some warnings, which stop the compilation very early. If I disable -Werror (CONFIG_WARNINGS_ARE_ERRORS=n) it again stops at ramstage/mainboard/lenovo/x220/gma-mainboard.o
The only way it compiles is with CONFIG_WARNINGS_ARE_ERRORS=n and ALL video (GFX and VGA) disabled. I've flashed the no-video image on the laptop and it worked except video output, of course, i.e. it booted up Linux.
Previous version worked flawlessly for me.
I'm including the piped logs of my latest failed attempt to compile (newly git-cloned repo shortly before submitting this) with -Werror and without al well as my defconfig.
Files
build_Werror.log (8.27 KB) build_Werror.log CONFIG_WARNINGS_ARE_ERRORS=y Vasile Dan, 07/30/2019 08:39 AM
build_no-Werror.log (34.3 KB) build_no-Werror.log CONFIG_WARNINGS_ARE_ERRORS=n Vasile Dan, 07/30/2019 08:39 AM
defconfig (882 Bytes) defconfig Vasile Dan, 07/30/2019 08:39 AM
No data to display
