Bug #154
open
MK
mainboard: via: epia-m700: NULL pointer dereference (if SeaBIOS is payload)
Bug #154: mainboard: via: epia-m700: NULL pointer dereference (if SeaBIOS is payload)
Added by Martin Kepplinger almost 9 years ago.
New
board support
01/19/2018
1.00 h
If you have a look at the following part of mainboard/via/epia-m700/wakeup.c
some bells must ring.
#if PAYLOAD_IS_SEABIOS == 1
    /* WAKE_MEM_INFO inited in get_set_top_available_mem in tables.c. */
    src =
        (unsigned char *)((*(u32 *) WAKE_MEM_INFO) - 64 * 1024 - 0x100000);
    dest = 0;
     * If recovered 0-e0000, then when resume, before WinXP turn on the
     * desktop screen, there is gray background which last 1sec.
    for (i = 0; i < 0xa0000; i++)
            dest[i] = src[i];
No data to display
