Bug #535
openT420: Power light stays off after reboot
I have recently encountered a bug in coreboot where if you reboot the computer, the keyboard power light will stay turned off after it turns back on. Where if you do a clean boot, the light turns on.
I am unsure whether this is a coreboot or payload issue. I am using GRUB as my payload.
Just run the reboot
command in Linux and it should be reproducible.
Priority set to Low
as it doesn't affect usability all too much.
Updated by Orest Worhacz 26 days ago
Just run the
reboot
command in Linux and it should be reproducible.Priority set to
Low
Hi I also noticed that. Which kernel are you using? I didnt update coreboot for long only system. And if I recall corectly it was not there before.
Updated by frantic from xboot 20 days ago
Orest Worhacz wrote in #note-1:
Just run the
reboot
Low
as it doesn't affect usability all too much.Hi I also noticed that. Which kernel are you using? I didnt update coreboot for long only system. And if I recall corectly it was not there before.
I tried using 5.15.152 up to 6.6.0. I don't think the kernel would have anything to do with this though.
