Bug #527
openCan't compile coreboot on Arch Linux
I want to compile coreboot for my Gigabyte GA-H61M-DS2 mainboard, but I only found a short guide for this board at this site: https://www.iot-tech.dev/full.php?ar=166
After downloaded the coreboot git repository, It gave me this error:
/home/zhongli/coreboot/util/crossgcc/xgcc/bin/x86_64-elf-ld.bfd: build/romstage/console/vtxprintf.o: in function `number':
/home/zhongli/coreboot/src/console/vtxprintf.c:63:(.text.number+0x12b): undefined reference to `__udivmoddi4'
/home/zhongli/coreboot/util/crossgcc/xgcc/bin/x86_64-elf-ld.bfd: build/romstage/lib/gcc.o: in function `__wrap___divdi3':
/home/zhongli/coreboot/src/lib/gcc.c:19:(.text.__wrap___divdi3+0x1): undefined reference to `__divdi3'
/home/zhongli/coreboot/util/crossgcc/xgcc/bin/x86_64-elf-ld.bfd: build/romstage/lib/gcc.o: in function `__wrap___udivdi3':
/home/zhongli/coreboot/src/lib/gcc.c:20:(.text.__wrap___udivdi3+0x1): undefined reference to `__udivdi3'
make: *** [src/arch/x86/Makefile.mk:191: build/cbfs/fallback/romstage.debug] Error 1
And I'll put my config file on here.
Any help ?
Files
Updated by Maximilian Brune 3 months ago
When I build this defconfig it works (at least without the payload). You could try removing the ANY_TOOLCHAIN option, because it seems like that your libgcc.a is not correct.
Updated by Nico Huber 3 months ago
Actually, this looks like it's using the reference toolchain, but the 64-bit one. xcompile
picks up 64-bit toolchains even if they don't have a libgcc for 32-bit builds.
If you are trying a 32-bit build (the default, so I guess yes), try make crossgcc-i386 CPUS=$(nproc)
